Generate API key button missing
jpjeffery
Hi!
I've enabled 'Enable access to the Cisco Meraki Dashboard API' as per https://documentation.meraki.com/General_Administration/Other_Topics/Cisco_Meraki_Dashboard_API#Enab...
The next step states to go to the My Profile page and click on the Generate API key button. However, there is no such button (even 24 hours later after ticking the 'Enable access...' checkbox).
Have I missed something?
Brash
Brash
Are you an Organisation admin in the Meraki Dashboard?
You can check under organization -> Administrators
jpjeffery
Yes, I am an Administrator (by SAML).
Brash
SAML dashboard administrators cannot view or generate API keys.
Reference: https://documentation.meraki.com/General_Administration/Other_Topics/Cisco_Meraki_Dashboard_API
SimunicIvan
Hi guys!
I am an organization admin and I have two-factor authentication enabled via email and DUO,  my colleague also has email and sms, and we both cannot generate API keys. I go to API & webhooks page and get a blank page. Is there something that we are missing?
Thanks!
