Firmware - template status "Critical" but devices status "Good"
N7717G
On the firmware upgrade manager page, the template for one site shows a status of "Critical" with very old firmware but the devices covered by that template show a status of "Good" with the newest firmware. Why does this happen, and how do I fix it?
When the status is critical, it means that there are important updates that need to be installed, such as fixing bugs and vulnerabilities.
Thank you, but that was not the question.
Is it a combined device template? If yes, it may be showing as critical for another type of device (like a switch for example). But it could simply be a cosmetic bug, so I suggest opening a support case.
N7717G
I found the problem. Someone had removed all the devices from those two templates and moved them into a different template, but did not remove the old templates themselves, and did not upgrade the templates.
