Facing issue with meraki AP
Knowledge_gainr
Dear All,
We are facing net access issues for the past 9 to 10 months, some of the users are not able to connect with MR devices and some are connected but getting a high ms rate while pinging.
Need help to resolve this issue from champions of network troubleshooting.
AxL1971
have you looked at the Health status of the wireless on the dashboard as to why clients cant connect
When they connect they do get an IP address
Have you collected wireshark trace from the AP's to troubleshoot
anything in the event logs to indicate your issues
Knowledge_gainr
Dear AxL1971,
Thank you for reply.
  • Yes health status is OK, client device taking ip but not able to access internet.
  •  Yes they will.
  •  Yes i collected logs but no luck.
  • In logs its showing TX power increased and changed.
AxL1971
have you looked at the Health status of the wireless as to why clients cant connect
Knowledge_gainr
Dear AxL1971,
Thank you for your reply.
  •  Yes, they will.
Have you collected Wireshark trace from the APs to troubleshoot
  •  Yes, I collected logs but no luck.
  • In logs, it's showing TX power increased and changed.
