Export Wireless Floorplans without API
SchoolWifiGuy
Hi, is there a way to export the wireless floorplans from the Meraki dashboard without using the API? The only known maps of our buildings were uploaded to the Dashboard to document APs, but the originals cannot be found. I can learn how to use the API if that is the only way but I was hoping to avoid it. Thanks!
-SWG
2 Replies 2
No, it's not possible.
What happens if you do a right click/save as in your browser?
