Enable WPN via API
Klingherit
Enable WPN via API
Hello. Is there any way of enabling WPN via an API call?
Many thanks.
KH
Meraki Employee All-Star
Hey @Klingherit
Practically everything other than the actual enabling of WPN setting is currently supported.
The following API can be used to create the Group Policies:
https://developer.cisco.com/meraki/api-v1/create-network-group-policy/
Afterwards the following API to create an IPSK SSID for example:
https://developer.cisco.com/meraki/api-v1/update-network-wireless-ssid/
Afterwards you can also create IPSKs with API:
https://developer.cisco.com/meraki/api-v1/create-network-wireless-ssid-identity-psk/
Then creating the port profiles:
https://developer.cisco.com/meraki/api-v1/create-network-wireless-ethernet-ports-profile/
Then assigning those port profiles to an MR30H/36H for example:
https://developer.cisco.com/meraki/api-v1/assign-network-wireless-ethernet-ports-profiles/
Finally you can check the IPSK/Port profile configuration:
https://developer.cisco.com/meraki/api-v1/get-network-wireless-ssid-identity-psks/
https://developer.cisco.com/meraki/api-v1/get-network-wireless-ethernet-ports-profiles/
I would recommend putting in a feature request by clicking the "Give your feedback" button on the dashboard or with speaking to your account team. It shouldn't be too hard to argue for such a feature.
Hopefully this helps!
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
Mikkelsen
Is there any news about how to enable WPN via an API call ?
I have 500+ networks where I need to enable WPN.
Mikkelsen
