Disconnect clients from SSID
BeepBop
Hi All,
    In one of our SSID we made some changes to the duration of splash page and added AD login for users. Before we made these changes SSID was open for all users. After making the changes I can still see there are clients connected from the previous session. We disabled and re-enabled the SSID but this did not disconnect the clients. We almost have 1000+ clients connected to this SSID across the organization and it's nearly impossible to individually revoke and disconnect clients due to the high volume. Is there a quick way in meraki to disconnect all the clients for this particular SSID?
Thank You,
AP: MR42
Firmware: MR 30.5
The only way is to revoke access. Perhaps doing it via API is an option, but I believe it will be more work than revoking via the dashboard.
1 Reply 1
