Hi everyone !
The title says it all, I'm wondering what is the actual difference in features and capabilities between the two patch antennas MA-ANT-3-E5 and E6. They have the same data sheet, so why do we have different numbers to identify them ?
Thanks in advance,
They are for different Models of APs. E6 should be for MR46E, E5 for MR42E if I remember right.
The e6 has 6 connectors, while the e5 has 5 connectors. As @KarstenI alluded to, they're used for MR's with the corresponding amount of connections
