Creating firewall Rule MR33 not allowing multiple IPs
mikesid
I'm not sure if this is a limitation with the APs that we have but i am trying to make a layer 3 firewall rule and for destination im trying to put in 192.168.0.100/32,192.168.0.101/32 and it won't accept it. It seems like it will only allow one IP or a subnet using CIDR. I would like to create a range but it doesn't allow that.
Is it possible to add multiple IPs in one area or is is going to force me to create a rule for each IP?
 I just gave it a try and had the same issue.
It seems the MR firewall do only allow a single item in the destination field.  You are going to need to add a line for each destination.
1 Reply 1
