Contacted at
Pedro
Contacted at
Hello everyone,
On the access points status page what does Contacted at really mean?
Because all times are reset, never exceed 2 hours, for example.
Can this be some instability of meraki cloud connection? Local network ? Or should I disregard?
Follow print below:
Thank you
Pedro
Pedro Constantino
2 Replies 2
It is usually when the AP last checked into the cloud.
Pedro
So okay, I should not worry.
It is that looking at the time gives fear of connection / disconnections.
Thank you
@PhilipDAth
Pedro Constantino
