I saw your thread and just want to give my feedback and experience when using Meraki infrastructure with Sonos devices.
I got a similar situation :
- 2x Fiber access at home with a MX68
- connected to a Meraki Switch MS220
- with one MR84 and 5x MR52
Sonos devices in all the property.
I learn the following :
- Sonos does not handle properly when a Sonos instance is running across multiple Meraki MR because they don't handle correctly different BSSID for the same SSID network when having multiple Meraki MR for the same SSID, my workaround for this is not simple :
- put maximum of Sonos devices using LAN network on a specific Vlan
- for Sonos devices using Wifi, I create a specific SSID with the same Vlan than above, on a specific Meraki MR to be sure they don't use multiple Meraki MR devices
Regarding the control and access to Sonos devices, because I am using only AirPlay 2 (all the other traffic is blocked) I have the done the following :
- my main SSID network is using 802.11x and 802.11r (with Fastlane enabled) with Meraki SM (Systems Manager), devices must be enrolled first to access this SSID just with certificate, this SSID has Air Play 2 support. All devices not enrolled cannot access this SSID because they need a device certificate. It's very easy to install.
- my guest SSID using simple WPA2 has AirPlay 2 blocked to the other SSID/Vlan
Here is what I did, hope that could help you.
My 2cts.
Nicolas
