I have added a Webex Deskpro to my (2) AP Meraki network at home. The APs are 9164s and the issue is my meetings keep dropping. Currently I have only 1 SSID and it's in WPA transition mode as I have some older devices on my network. Any QoS thoughts or thoughts in general would be great. The deskpro is within 6 feet and the AP and the signal strength is 100%. I am a little stumped so any thoughts would be great. Worst case I could cable it, but its not preferred!
Don't use WPA3 Transition mode. It has terrible compatibility with devices.
If you want to use WPA3, create a seperate SSID for it. Then you can try moving devices across, and if they don't work reliably (or at all), move them back.
