Cisco Meraki - Access Point offline - Connection logs stops ?
ADF
I had an access point loose connectivity to the internet according to the Meraki portal  , but active connections to that access point still receive internet .
> Connections logs according to the portal shows a gap during the time that Meraki Cloud shows it as offline . (No entries)
> Does this mean you don't have logs of connections to the AP , even if its just locally if there is a failure in communication to Meraki cloud or if there is internet provided but Meraki shows it as offline ?
(eg. Internet goes down locally on site or Meraki has outage  , you have no way to see what devices connected to the device during this outage even if the connection were just for local access to resources like printers / local servers ?)
0 Replies 0
