I personally am not a fan. You should be aware of the environment your wireless gear is sitting in.
If your in the middle of nowhere and only have one or two access points, then you could leave 80MHz
If your in a crowded metro area, I would use 20MHz
If you have lots of access points in an office design, I would use 20MHz
