Dear Community,
I have been battling some intermittent connectivity issues in our 5Ghz range lately and wanted your opinion. I am currently using the Default Indoor Profile for my deployment but am noticing some strange things. My deployment is in an office building on the very top floor that has a few other 5Ghz range SSID's but very low channel interference from the environment. Here is a snapshot of what I am seeing:
If you notice above how AP's 1704 and 1705 who are adjacent to eachother are using the same channel (60) and again 1707 and 1708 (56). Wouldn't this cause co-channel interference? Why did Meraki dynamically select the same channel on 2 AP's that overlap? Also, if you notice the channel #s being used in the 80Mhz width, why is Meraki not referencing the center channel as per the 802.11ac guideline? For instance AP1703 is using channel 108 in the 80Mhz width, But 106 is the center channel for that width. Same with Channels 56 (58 is the center channel) and 104 (106 is the center channel). Some things just arent adding up here:
Would you recommend I statically assign the 40Mhz channel to this 5Ghz range in my deployment? I really don't see the need to have 80Mhz channel widths as we have a semi-dense deployment where interference could be a factor here. And since Meraki doesnt seem to provide away to just exclude the 80Mhz widths from its dynamic assignment, I don't see any other choice but to statically assign it.
Please let me know your thoughts. Thanks!
