We have launched two captures filtering with customer MAC address.
The result is the same: the capture is stopped witouth reason.
Could you help us on this topic ?
Have you tried with another browser? If so, I suggest you open a support case.
Yes, captures have been made with two differents browsers.
Unless I don't understand your question , you have specified a 3600s capture duration and you have reach the limit. That's probably why it stopped.
I have made the test with another duration (1200).
In both cases, I do not retrieve pcap files.
Your filter expression won't work on wireless interfaces.
Thanks for your reply Raphael.
You have reason ... my bad 😅
You could try actual wireless capture filters.
With some luck you could filter your mac address if it is the transmitter or receiver address by using following filter.
wlan addr1 <mac address> or wlan addr2 <same mac address>
Thanks for the wireless capture filter given.
I have try it but I still have an error.
I finally launched capture with no filter and put a filter in Wireshark.
