How is the switch on which the AP is connected, configured?
Since you are tagging packets with VLAN 100, you need to make sure that VLAN 100 is configured on the switches.
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
