Can an EWC 9120 be added to the Meraki dashboard?
ReyesPolanco
Recently, a question arose about adding an EWC 9120 to the Meraki dashboard.
I was reading and saw that a 9120 is supported, as long as it is connected to a WLC9800.
Taking this into account, would it be possible to add an EWC to the dashboard?
GIdenJoe
Alas no, it is only intended for fully featured controllers.
For now only the physical controllers are supported C9800-40, 80, and -L.
EWC is also end of sale btw so I doubt it will be added.
If you have a medium deployment of C9120AX(I or E) AP's you will need to migrate to a controller and pay for licenses before being able to pull in the controller in dashboard.
GIdenJoe
GIdenJoe
Oh I forgot to mention in my post that the C9800-CL (virtual controller) will be supported down the line.
ReyesPolanco
Thanks for your answer, its very useful! Thnx again!
