Cambiar contraseñas a las SSID
NEFTALICABRERA
Buen día.
Solicitando de su apoyo, ¿Como puedo cambiar de contraseña a mis SSID desde meraki, y que se actualice en automatico a los equipos conectados.
Espero contar con su ayuda.
Saludos.
2 Replies 2
No, if you change the PKS all devices will be required to re-enter the password.
Unless you are using iPSK.
TimYeo
Hi there,
Forgive me as I did only use Google translate so the accuracy of my answer may not be the best. My interpretation of your question is that you would like to have it such that your clients also automatically update the PSK.
From the MR's perspective, this is not something it would not push out. Likely you would have to use a client profile manager to achieve what you would like to do.
