Blocking meraki status page on Guest SSID
AreEyePea
Does any know how to block the Meraki status page for a guest SSID?
If you connect to our guest network, you connect to the /16 Meraki provides. If you go to the gateway address 10.128.128.128, it pulls up the meraki status page and gives you what AP you're connected to and ipconifg info. There is also a config tab at the top that, when trying to click that tab, pulls up and asks for a username and password. With enough attempts, an adversary would be able to crack that. So my question, is there a way to block that status page on the guest SSID?
I have tried blocking that via the wireless firewall settings and was not successful.
Thanks for the help!
I personally always leave it disabled and only enable it when I need to do some troubleshooting.
This is a global setting, and if you disable it, it will disable the entire network.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me....
But you can try to block traffic to the LAN on the firewall page.
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/'Deny_Local_LAN'_settings_in_Cisco_...
AreEyePea
Yeah, I was thinking about doing this as well. Just wanted to see if you could block it without disabling it globally.
Thanks for the feedback!
