Hey @Paul03 !!!
Thanks for taking the time!
And to answer your question: Absolutely! ...at least on your Meraki wireless.
Find the client on your dashboard under Network-Wide -> Clients then select the particular wireless client. You'll notice near the bottom of the page there will be a Policy section. Select the the device policy dropdown and modify per SSID as needed. (As shown below)
Hope this helps!
-Cheers!
