Being redirected to anti-virus scan
Josh_C
using MR33 AP, have the AP set wide open (Meraki DHCP), still point my clients to scan for anti-virus prior to connection. What am I missing?
MerakiDave
Meraki Employee All-Star
Check your SSID settings on the "Access Control" page, if you are using any type of splash page, and if so, there could be a setting for Network Access Control that's enabled to check clients for AV software that you would want to disable.  If you are running the SSID wide open with no splash page and in NAT mode with no content filtering, then something further upstream must be redirecting the clients to the AV scan other than the MR33.
1 Reply 1
MerakiDave
