Be gone
Johnlee3
Be gone
I have a MR32 that is fried from power surges. How do I remove it from the network and our inventory completely.
1 Reply 1
HodyCrouch
Login to Meraki Dashboard and select the network containing the access point you want to remove.
Wireless > Access points
Click the checkbox next to the access point and select 'Remove from network' from the Edit dropdown.
Organization > Inventory
Click the checkbox next to the access point and click 'Remove from network' from the Edit dropdown.
