BYOD setup for Meraki single SSID on ISE
Cyrus777
Hello.
I am having a hard time to figure out some issues that I have with BYOD single SSID setup for Meraki network on ISE. I have followed this document and video to configure BYOD for our org. I get to the point that I can login with AD user/password and pass the PEAP (EAP-MSCHAPv2) authentication. from this point on Windows devices I get the redirect URL to my ISE and download the NSA successfully but when I try to install the NSA I get an error for untrusted cert and I continue but it fails eventually.
For Mac OS ad iOS (iPhone) I download the cert but it doesn't move to next policy to eap-tls.Image (15).jpgImage (14).jpg
I'm allowing all traffics to ISE / DNS and other required webpages on walled garden on Meraki access control page for this SSID.
Take a look at this document.
https://community.cisco.com/t5/security-knowledge-base/how-to-integrate-meraki-networks-with-ise/ta-...
Search for BYOD.
Cyrus777
this doc is not helpful!
This documentation is for you to review your settings.
I also suggest that you check the ISE logs to try to find any errors, as well as a packet capture.
And finally I suggest you open a support case.
