Android MS Cloud PKI Local Auth
EvanBaumgartner
Has anyone had success getting Android to connect to Wi-Fi via Local Auth using MS Cloud PKI?
We are trying to move some of our Android MS Intune devices to use Local Auth with Certificate authentication
instead of LDAP. But we have been having trouble getting it working.
EvanBaumgartner
Hi Alessandro!
I actually just figured it out right before you replied lol.
The issue stemmed from the Radius server name not being set correctly within Intune and the Identity privacy (outer identity) needing to be "anonymous".
2 Replies 2
Take a look at this, maybe it will help you.
Azure Cloud PKI is now released; how do we hook Meraki AP to it? - The Meraki Community
EvanBaumgartner
Hi Alessandro!
