Airplay/ClearPass AirGroup/ Meraki
kYutobi
I have a school that uses AirGrouping for AppleTV. They asked if Meraki does something of that nature where you can see only whats assigned when it's connected to an AP. Is there a certain way to sort of designate? Please advise 😀
Enthusiast
5 Replies 5
I don't know if I understood your question correctly, but perhaps this article can help you.
Watch Apple TV over secure guest WiFi | Cisco Meraki Blog
kYutobi
@alemabrahao My apologies. Basically clearpass does something called airgrouping where you can group Apple TVs and the group can be tied to AP's by location, what can be displayed, etc. I'm just asking what would be a recommendation on how can I do this with Meraki in a way that it's kind of the same. Should I SSID some Apple TVs and put them in certain VLANs by floor? Should sectioning be my best option and go from there?
Enthusiast
I'm not familiar with clearpass, but in my understanding it is Aruba's NAC, similar to Cisco ISE correct?
If that is the only possibility I see would be using Cisco ISE.
Did you read the article I sent? Maybe it's a solution for what you're looking for. You may want to consult your Meraki sales representative.
kYutobi
I have my guy 😀. Thank you.
Enthusiast
