- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ARP Failures: How to fix
Good morning,
My site has been Meraki and trouble-free for 5 years but recently we have had to restart AP's left, right and center to combat slow speeds and connectivity issues.
This morning I have noticed many AP's have "ARP failures" but am struggling to find out how serious this is and how to remedy the issue. The Meraki notes I found don't seem to explain it all that well. From what I gather, its maybe a problem when a client roams between AP's and guessing it can be ignored but feel I should be doing something.
Thank you
- Labels:
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Often that means it is having trouble contacting the default gateway. Is a Meraki MS or MX the default gateway for the APs?
Also, check Organization/Firmware Upgrades, and see if there have been any recent firmware updates around the time the problems started.
While you are there, check that the APs are running a minimum of the latest stable firmware.
