802.11r FastRoaming capable clients not reporting correctly?
Sprocket
I've set up av new SSID with WPA2 enterprise (radius) and 802.11r enabled and clients consist of a mixture of iOS and Windows devices. The strange thing is that ONLY iOS devices are reported 802.11r capable in dashboard, not the Windows client?!
I also see successfully 802.11r roamings on iOS devices in the event log.
The windows clients are fairly new and I checked 11r compatibility with Intel.
According to MS this should be default enabled on the OS level (as long as you run 802.1x) and I can't find any related settings on the wifi adapter advanced settings.
Has anyone successfully got this working and reporting correctly in dashboard on Windows clients at all?
1 Reply 1
wifijanitor
This is from my dashboard:
Epson Printer
iPhone
If it is just a matter of the client reporting their capabilities to the dashboard, that could 100% be due to the Cisco Meraki/Apple partnership, which includes things like Fastlane(+), allows us to get more information from the device drivers than we do with other devices, as seen above.
