1 of 4 SSID's has no connection to internet
BAnderson
We have a template with two locations bound to it.  Both locaitons have 4 SSID's and 3 of the 4 work fine.  The 4th, at both locations does not allow devices to connect to the internet.  At both of the locations I am getting this error on the dashbaord.  The device is an MR52.
  • This device is using a DHCP IP address from VLAN 50 instead of using configured VLAN 1.
How do we resolve this?  We have changed the primary VLAN assignment for the port in our meraki switch that the WAP plugs into, both in the local network port settings and on the template settings.  This doesn't fix it.  The device is an MS120 24P.
The SSID that doesn't work is set to tag VLAN 10.  The settings for the port in the meraki switch that the WAP plugs into is a trunk port with allowed access to all VLAN's and has primary VLAN of 50.  We tried changing the primary VLAN and that had no impact.
Thanks in advance for your suggestions.
Try removing the VLAN tag from the AP's IP address, i.e. leave the field blank under the DHCP selection.
1 Reply 1
