Wireless WAN on X220
konarktriv7
I've got a ThinkPad X220 that doesn't have a wireless WAN PCI-E card inside it, or the antennae (I can only see the WiFi antennae when I open it up). It does have a SIM card port underneath the battery, though.
Can I add wireless WAN to it?
2 REPLIES 2
Are  you referring to the mg21? This device takes care of the connection and let you connect  your device to a rj45 ethernet  port.
https://meraki.cisco.com/lib/pdf/meraki_datasheet_MG21.pdf
https://documentation.meraki.com/MG/MG21%2F%2FMG21E_Installation_Guide
Uberseehandel
If you have good contacts, you might be able to find an original part, but the X220 is an old model and I doubt that many replacement components are still stocked. You might get lucky.
In your shoes, I'd consider using a LTE modem that would plug into a USB or Ethernet port. This would be easier to acquire, and would potentially offer higher throughput than you would get from comparatively aged technology.
Otherwise, tether a smartphone to the X220 and share the phone's connection.
