Hey Philip,
You are correct, the MG is online, but not using the desired APN. To use the one we want would require manually having the MG in hand to change, since the default APN isn't allowing AutoVPN to work. If we could have the provider block the default APN, so that the MG would be forced to use the one we want, that would be great. Unfortunately, the provider isn't certified for the MG - eventhough it's the largest ISP in Denmark. Heck, the MG21 contains a Centurion chip, same as a Huawei, iirc.
Of course, we could probably just have each site provide a laptop, which we could take control of, and reconfigure the APN that way. But that kind of defeats the purpose of the Zero Touch Provisioning, and add additional time and cost in the deployment. We're not just talking about tens of sites, but hundreds.
