Sponsored guest
Dav
Sponsored guest
When guest users trying to connect to Meraki splash page, getting message
this page website security certificate issue
anyway to fix ssl certificate issue or how we can add certificate to meraki splash page?
thanks
2 Replies 2
You wont be able to add a certificate.
Typically most device do captive portal detection so this should not be an issue.  It should only be an issue if they already have a web page open to an https site, then connect, and then click refresh.
Philip,
thanks for that
do you know why guest getting this certificate issue before getting the sponsor page ?
