Meraki Go 5 Port Security Gateway & VOIP/Voice (SIP_ALG)
John01
Does the Merak Go support VOIP/Voice.  Is there a config parameter to disable ALG?  I'll create a VLAN for the voice phones, but need to ensure the device will support voice/VOIP and QOS.
1 Reply 1
GIdenJoe
Hey, your question is on the wrong forum.
Wireless WAN only covers the MG gateway product.
You should go to the correct Meraki Go forum for this.
In enterprise Meraki there is not support for SIP ALG, so we could assume this will also be the case on Meraki Go.
