MG21 issue
hwood
Just browsing
MG21 issue
We have a few MG21's that frequently go offline, and the only way to get back online is a reboot.  There are no logs for the issue in the MX.  Anyone else experience this, and know why it happens?
7 REPLIES 7
Not seen this issue.
There should also be a MG logging.
The 4g internet is down or just the management tunnel?
Could you try another apn if your LTE provider supports that
hwood
Just browsing
We look in the portal, and you see the big red line, and it says device is offline.  Reboot the device and back online.
I haven't seen this issue either.
Is the firmware up to date?
Yes, up to date.
CptnCrnch
Sounds like a defective unit. I‘d file a case with Meraki support.
GaelGiraud
Have you deployed beta version 1.11?
Here is what we find in the changelog: MG 1.11 has a number of improvements under the hood with fixes to devices falling offline and issues with enterprise/private APN.
rsage_voda
Hi I have similar issue on firmware 1.9 did the upgrade to 1.11 fix the issue.
