removing one ap and deploy another on the network
lilmeat
Just browsing
how do i backup my ap so i can use the settings on another ap?   going from a mr18 to the mr26
KarstenI
Nothing to do here as the config is assigned to the network and not the individually AP. Add the new one to the network and it will directly fetch the config. The old one can be removed.
What has to be applied additionally:
  • IP-information if needed (for example if you use WPA-Enterprise).
  • RF-Profiles
  • Tags for the SSID availability
so i will have to go and reinput the ssids back in ?
ip address for the ap
KarstenI
All what you find on the WLAN configuration is automatically applied. This includes the SSID settings. IP-settings are done per AP. If you want that the new AP has the same IP as the old one, this has to be done manually.
