mesh network?
Pogi
Just browsing
mesh network?
Trying to build a lab with wireless APs connecting to LAN and LAN to APs. I made one gateway and one repeater. I connected the repeater to a switch but when I plugged in my PC to the switch I cant get in to the network. it is saying on my Ethernet. Unauthenticated.
2 Replies 2
Did you set:
Network-wide > Configure > General > Device configuration, find the option to configure Clients wired directly to Meraki APs, and set that option to have clients behave like they are connected to the bridge SSID .
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Extending_the_LAN_with_a_Wireless...
Pogi
Just browsing
I did. it seems it is trying to use vlan 206. do I need to add that Vlan to the layer 3 switch where my gateway is connected?
