Wireless feature differences between MR33 and MX65W
I've searched but can't seem to find a simple page showing the wireless capabilities differences/features between the MR33 AP and the MX65W  (wireless features only).
Would anyone know all of the additional functionality/features (AirMarsal etc)  that a MR33 would have over the MX65W?
Thanks in advance.
3 REPLIES 3
Re: Wireless feature differences between MR33 and MX65W
I don't think the Wireless menu even shows up when you just have the MX-W models. So I think most features there will not be supported:
Check this link which shows what the wireless configuration looks like on an MX: https://documentation.meraki.com/MX/Wireless/Creating_a_Wireless_Guest_VLAN_on_a_Z-series_Teleworker...
The built in APs have severly retarded functonality compared to the full APs.  Basically you can do PSK or WPA2-Enterprise mode, and that is about it.
I don't think there are any splash pages or any of the other advanced functionality.
One major feature is the the builtin WiFi in MXs will not mesh of work as a "seamless" SSID with other MR in the same network, the SSID on the MX will appear as "separate" to the SSID of the MRs even though you may name them the same.
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Wireless_Mesh_Networking
