Wireless Portal - Radius Auth - Change Splash "I forgot my password" link to custom URL?
I have the splash page portal working with RADIUS authnetication fine, but I want to change the existing "I forgot my password" link to go to our service's reset page. I copied the Modern theme to customize it, but there isn't an obvious way to hide the current reset password link or change it to my own.
Accepted Solutions
Re: Wireless Portal - Radius Auth - Change Splash "I forgot my password" link to custom UR
It's embedded in the $MERAKI:MODERN_AUTH_ALREADY_HAVE_ACCOUNT_SIGN_IN_HERE_FORM$ token. But you won't be able to separate the forgot password link from "Sign in" button as that is in there too.
You can hide the link with CSS though:
#forgot_password {
  display: none;
5 REPLIES 5
Click on the pencil on the right hand side to be able to edit the raw pages.
Yes I'm looking at the code, but there isn't anything that looks like the link. It is tokenized and I don't find these tokens in the documentation.  Which token represents the "I forgot my password" link so that I can remove it and put my own, while keeping the authentication functionality that does work?
I don't know.  Have you checked the other pages?
#forgot_password {
  display: none;
That's perfect, thank you!
