Wireless Client Isolation
Rushan_Thilina
Just browsing
What is the Layer 2 LAN isolation enabled / disabled in bridge mode only? can explain any one? and i want to make wireless users like NAT mode but i need issue manageable IP issue from my DHCP server, if i enable this isolation mode? is it clients are not communicate each other?
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/Wireless_Client_Isolation#Overview
In nat mode the mr is dhcp server and assigns  the user a IP.
Inderdeep
@Rushan_Thilina : apart from what @ww said, In the NAT mode: Use Meraki DHCP
Clients receive IP addresses in an isolated 10.0.0.0/8 network. Clients cannot communicate with each other, but they may communicate with devices on the wired LAN if the SSID firewall settings permit.
Check this thread as well
Regards/Inder
www.thenetworkdna.com
Agus
That correct, if isolation mode enable between each client on same network will cannot communicate. correct me i'm wrong.
