I need a rule to allow wifi connections to access OpenVPN.
The default port for OpenVPN is UDP/1194. If that is the port the OpenVPN server is using (it can be changed), you just have to allow this port.
Thanks, I will give it a try.
View all community news »
\\n\\t\\t\\t\\t\\t\\tSorry, unable to complete the action you requested.\\n\\t\\t\\t\\t\\t<\\/p>\\n\\t\\t\\t\\t\\n\\n\\t\\t\\t\\t\\n\\n\\t\\t\\t\\t\\n\\n\\t\\t\\t\\t\\n\\t\\t\\t<\\/div>\\n\\n\\t\\t\\t\\n\\t\\t<\\/div>\";LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_1ae205127fe45', 'disableAutoComplete', '#ajaxfeedback_1ae2050d79da8_0', 'LITHIUM:ajaxError', {}, 'EpGeW3NdDRQ6BHmMBV1aTGFCz7hjRH9roNKoIiqSsaE.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":3},"inputSelector":"#messageSearchField_1ae2050d79da8_0","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.messagesearchfield.messagesearchfield:autocomplete?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.AutoComplete({"options":{"triggerTextLength":4,"updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_1ae20519382f1', 'disableAutoComplete', '#ajaxfeedback_1ae2050d79da8_0', 'LITHIUM:ajaxError', {}, 'pvtK1jd7XrBYE9Ji-SISXVnuVUtCY99C3Sp73xpqgIM.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":3},"inputSelector":"#messageSearchField_1ae2050d79da8_1","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.tkbmessagesearchfield.messagesearchfield:autocomplete?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.Placeholder(); LITHIUM.AutoComplete({"options":{"triggerTextLength":0,"updateInputOnSelect":true,"loadingText":"Searching for users...","emptyText":"No Matches","successText":"Users found:","defaultText":"Enter a user name or rank","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_1ae2051bb9a9b', 'disableAutoComplete', '#ajaxfeedback_1ae2050d79da8_0', 'LITHIUM:ajaxError', {}, 'LQeoXq4z13lPcT0-BRFKDrVj3pLDKBXNwoHI3Unb8V4.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":0},"inputSelector":"#userSearchField_1ae2050d79da8","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.usersearchfield.usersearchfield:autocomplete?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:userExistsQuery","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":"#userSearchField_1ae2050d79da8","action":"userExistsQuery","feedbackSelector":"#ajaxfeedback_1ae2050d79da8_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.usersearchfield:userexistsquery?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=search/contributions/page","ajaxErrorEventName":"LITHIUM:ajaxError","token":"LuCCLf_J7tDS6XoPOiVlG7kvOOuFf3WnQUKoHGv0fSU."}); LITHIUM.AutoComplete({"options":{"triggerTextLength":4,"updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_1ae2051e14c44', 'disableAutoComplete', '#ajaxfeedback_1ae2050d79da8_0', 'LITHIUM:ajaxError', {}, 'fF3xItHJMKMiVa6DKc0nKpUp1wLF-a2vB4OABRZwoFk.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":0},"inputSelector":"#noteSearchField_1ae2050d79da8_0","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.notesearchfield.notesearchfield:autocomplete?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.AutoComplete({"options":{"triggerTextLength":4,"updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_1ae205206328b', 'disableAutoComplete', '#ajaxfeedback_1ae2050d79da8_0', 'LITHIUM:ajaxError', {}, 'P2xVOquufD2XVFbmwGpn96Avp_6-8fl0r5WXHnb7BxY.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":0},"inputSelector":"#productSearchField_1ae2050d79da8","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.productsearchfield.productsearchfield:autocomplete?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.Link({"linkSelector":"a.lia-link-ticket-post-action"}); LITHIUM.AjaxSupport.fromLink('#enableAutoComplete_1ae2050d79da8', 'enableAutoComplete', '#ajaxfeedback_1ae2050d79da8_0', 'LITHIUM:ajaxError', {}, 'gw_sW0II-h0dOSgLGUGIM0e-PswAlyj8vJHBuci2TCY.', 'ajax'); LITHIUM.Tooltip({"bodySelector":"body#lia-body","delay":30,"enableOnClickForTrigger":false,"predelay":10,"triggerSelector":"#link_1ae2050d79da8","tooltipContentSelector":"#link_1ae2050d79da8_0-tooltip-element .content","position":["bottom","left"],"tooltipElementSelector":"#link_1ae2050d79da8_0-tooltip-element","events":{"def":"focus mouseover keydown,blur mouseout keydown"},"hideOnLeave":true}); LITHIUM.HelpIcon({"selectors":{"helpIconSelector":".help-icon .lia-img-icon-help"}}); LITHIUM.SearchAutoCompleteToggle({"containerSelector":"#searchautocompletetoggle_1ae2050d79da8","enableAutoCompleteSelector":".search-autocomplete-toggle-link","enableAutocompleteSuccessEvent":"LITHIUM:ajaxSuccess:enableAutoComplete","disableAutoCompleteSelector":".lia-autocomplete-toggle-off","disableAutocompleteSuccessEvent":"LITHIUM:ajaxSuccess:disableAutoComplete","autoCompleteSelector":".lia-autocomplete-input"}); LITHIUM.SearchForm({"asSearchActionIdSelector":".lia-as-search-action-id","useAutoComplete":true,"selectSelector":".lia-search-form-granularity","useClearSearchButton":false,"buttonSelector":".lia-button-searchForm-action","asSearchActionIdParamName":"as-search-action-id","formSelector":"#lia-searchformV32_1ae2050d79da8","nodesModel":{"wireless-lan|forum-board":{"title":"Search Board: Wireless LAN","inputSelector":".lia-search-input-message"},"tkb|tkb":{"title":"Knowledge base","inputSelector":".lia-search-input-tkb-article"},"meraki|category":{"title":"Search Community: Wireless LAN","inputSelector":".lia-search-input-message"},"enterprise|category":{"title":"Search Category: Wireless LAN","inputSelector":".lia-search-input-message"},"user|user":{"title":"Users","inputSelector":".lia-search-input-user"}},"asSearchActionIdHeaderKey":"X-LI-AS-Search-Action-Id","inputSelector":"#messageSearchField_1ae2050d79da8_0:not(.lia-js-hidden)","clearSearchButtonSelector":null}); // LITHIUM.DropDownMenu({"userMessagesFeedOptionsClass":"div.user-messages-feed-options-menu a.lia-js-menu-opener","menuOffsetContainer":".lia-menu-offset-container","hoverLeaveEvent":"LITHIUM:hoverLeave","mouseoverElementSelector":".lia-js-mouseover-menu","userMessagesFeedOptionsAriaLabel":"Show contributions of the user, selected option is Options. You may choose another option from the dropdown menu.","disabledLink":"lia-link-disabled","menuOpenCssClass":"dropdownHover","menuElementSelector":".lia-menu-navigation-wrapper","dialogSelector":".lia-panel-dialog-trigger","messageOptions":"lia-component-message-view-widget-action-menu","menuBarComponent":"lia-component-menu-bar","closeMenuEvent":"LITHIUM:closeMenu","menuOpenedEvent":"LITHIUM:menuOpened","pageOptions":"lia-component-community-widget-page-options","clickElementSelector":".lia-js-click-menu","menuItemsSelector":".lia-menu-dropdown-items","menuClosedEvent":"LITHIUM:menuClosed"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#pageInformation","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_0","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_1","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenu({"userMessagesFeedOptionsClass":"div.user-messages-feed-options-menu a.lia-js-menu-opener","menuOffsetContainer":".lia-menu-offset-container","hoverLeaveEvent":"LITHIUM:hoverLeave","mouseoverElementSelector":".lia-js-mouseover-menu","userMessagesFeedOptionsAriaLabel":"Show contributions of the user, selected option is Show Wireless AP - How to create a Firewall rule to allow access to OpenVPN. post option menu. You may choose another option from the dropdown menu.","disabledLink":"lia-link-disabled","menuOpenCssClass":"dropdownHover","menuElementSelector":".lia-menu-navigation-wrapper","dialogSelector":".lia-panel-dialog-trigger","messageOptions":"lia-component-message-view-widget-action-menu","menuBarComponent":"lia-component-menu-bar","closeMenuEvent":"LITHIUM:closeMenu","menuOpenedEvent":"LITHIUM:menuOpened","pageOptions":"lia-component-community-widget-page-options","clickElementSelector":".lia-js-click-menu","menuItemsSelector":".lia-menu-dropdown-items","menuClosedEvent":"LITHIUM:menuClosed"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_0","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.CustomEvent('.lia-custom-event', 'click'); LITHIUM.AjaxSupport.fromLink('#kudoEntity', 'kudoEntity', '#ajaxfeedback', 'LITHIUM:ajaxError', {}, 'nMJqd6oTUnvnxwyBMH3ghc93pA3nXoYxFuz4Fu2AJms.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "182412", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","renderEventParams":{"replyWrapperId":"replyWrapper","messageId":182412,"messageActionsId":"messageActions"},"isRootMessage":true,"collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions","loaderSelector":"#loader","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer","loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false,"linearDisplayViewSelector":".lia-linear-display-message-view","threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","isLazyLoadEnabled":false,"layoutView":"threaded","isAllowAnonUserToReply":true,"replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"_cq6bJaRCGsJX8TQ1x6nWwKK8nwXISUFH0WVn2Rco-c."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"b2dGRDbBGE6h1wDM6F9RpvfJBRIZcfsUumsZIcH1Aas."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "182412", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1101110111111111111110111110100101111101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_2","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenu({"userMessagesFeedOptionsClass":"div.user-messages-feed-options-menu a.lia-js-menu-opener","menuOffsetContainer":".lia-menu-offset-container","hoverLeaveEvent":"LITHIUM:hoverLeave","mouseoverElementSelector":".lia-js-mouseover-menu","userMessagesFeedOptionsAriaLabel":"Show contributions of the user, selected option is Show comment option menu. You may choose another option from the dropdown menu.","disabledLink":"lia-link-disabled","menuOpenCssClass":"dropdownHover","menuElementSelector":".lia-menu-navigation-wrapper","dialogSelector":".lia-panel-dialog-trigger","messageOptions":"lia-component-message-view-widget-action-menu","menuBarComponent":"lia-component-menu-bar","closeMenuEvent":"LITHIUM:closeMenu","menuOpenedEvent":"LITHIUM:menuOpened","pageOptions":"lia-component-community-widget-page-options","clickElementSelector":".lia-js-click-menu","menuItemsSelector":".lia-menu-dropdown-items","menuClosedEvent":"LITHIUM:menuClosed"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_1","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay_0', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity_0', 'kudoEntity', '#ajaxfeedback_0', 'LITHIUM:ajaxError', {}, 'g4nbrOhypZ4TO6jsT_LtJvhfv7qYL35mfDUBLBSIsoI.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2_0", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "182414", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","renderEventParams":{"replyWrapperId":"replyWrapper_0","messageId":182414,"messageActionsId":"messageActions_0"},"isRootMessage":false,"collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions_0","loaderSelector":"#loader","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer_0","loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false,"linearDisplayViewSelector":".lia-linear-display-message-view","threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","isLazyLoadEnabled":false,"layoutView":"threaded","isAllowAnonUserToReply":true,"replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_0","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"Q_97J_DmfBj4srPODL-my1qEqJD4S70y2JH8FvjkMqA."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_0","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"Cgunll4yp2PotxDWVwmvefRA1-VBuUOXFgRxpw3Z8aM."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview_0", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "182414", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1111110111111111111110111110100101011101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddetaildisplaymessageviewwrapper","componentSelector":"#threadeddetaildisplaymessageviewwrapper","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":182414,"confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","loaderSelector":"#threadeddetaildisplaymessageviewwrapper .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddetaildisplaymessageviewwrapper","action":"renderInlineEditForm","feedbackSelector":"#threadeddetaildisplaymessageviewwrapper","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist.threadeddetaildisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434","ajaxErrorEventName":"LITHIUM:ajaxError","token":"W-ASZt7jUfEOnEvWPH8akRFaIy-KVkRn-77sDtcpr2c."}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_8","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_2","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay_1', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity_1', 'kudoEntity', '#ajaxfeedback_1', 'LITHIUM:ajaxError', {}, '__UjrX8h6WKYHOhHp_z4kNW7B5mETu5tdcBkNiPTwZc.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2_1", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "182417", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","renderEventParams":{"replyWrapperId":"replyWrapper_1","messageId":182417,"messageActionsId":"messageActions_1"},"isRootMessage":false,"collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions_1","loaderSelector":"#loader","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer_1","loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false,"linearDisplayViewSelector":".lia-linear-display-message-view","threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","isLazyLoadEnabled":false,"layoutView":"threaded","isAllowAnonUserToReply":true,"replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_1","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer_1","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"bdK9xppMuaqLQhHfxNdYX2N4fib1UH0Ect-vqkrtLsE."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_1","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer_1","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"QYTxCiWp_Z8wZQlwEhWV_HLOu8JLoxZ19FQiOEWST8M."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview_1", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "182417", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1111110111111111111110111110100101011101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddetaildisplaymessageviewwrapper_0","componentSelector":"#threadeddetaildisplaymessageviewwrapper_0","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":182417,"confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","loaderSelector":"#threadeddetaildisplaymessageviewwrapper_0 .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddetaildisplaymessageviewwrapper_0","action":"renderInlineEditForm","feedbackSelector":"#threadeddetaildisplaymessageviewwrapper_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist.threadeddetaildisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434","ajaxErrorEventName":"LITHIUM:ajaxError","token":"fXJd7UGePUEOXXDqsaBWem-fxkF6sNWKBD75XD9Y4_8."}); LITHIUM.ThreadedDetailMessageList({"renderLoadMoreEvent":"LITHIUM:renderLoadMoreMessages","loadingText":"Loading...","placeholderClass":"lia-messages-threadedDetailList-placeholder","loadFetchSelector":"#threadeddetailmessagelist .lia-load-fetch","rootMessageId":182412,"loadPageNumber":1}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderLoadMoreMessages","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":"#threadeddetailmessagelist .lia-load-fetch","action":"renderLoadMoreMessages","feedbackSelector":"#ajaxFeedback","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist:renderloadmoremessages?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434","ajaxErrorEventName":"LITHIUM:ajaxError","token":"lJm5_xtjF_OEkvFZWHquyVc5PoBX2k3_-QkpRaQ9b1s."}); LITHIUM.InlineMessageReplyEditor({"openEditsSelector":".lia-inline-message-edit","ajaxFeebackSelector":"#inlinemessagereplyeditor_0 .lia-inline-ajax-feedback","collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","topicMessageSelector":".lia-forum-topic-message-gte-5","focusEditor":false,"hidePlaceholderShowFormEvent":"LITHIUM:hidePlaceholderShowForm","formWrapperSelector":"#inlinemessagereplyeditor_0 .lia-form-wrapper","reRenderInlineEditorEvent":"LITHIUM:reRenderInlineEditor","ajaxBeforeSendEvent":"LITHIUM:ajaxBeforeSend:InlineMessageReply","element":"input","clientIdSelector":"#inlinemessagereplyeditor_0","loadAutosaveAction":false,"newPostPlaceholderSelector":".lia-new-post-placeholder","placeholderWrapperSelector":"#inlinemessagereplyeditor_0 .lia-placeholder-wrapper","messageId":182412,"formSelector":"#inlinemessagereplyeditor_0","expandedClass":"lia-inline-message-reply-form-expanded","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","newPostPlaceholderClass":"lia-new-post-placeholder","isLazyLoadEnabled":false,"editorLoadedEvent":"LITHIUM:editorLoaded","replyEditorPlaceholderWrapperCssClass":"lia-placeholder-wrapper","messageActionsClass":"lia-message-actions","cancelButtonSelector":"#inlinemessagereplyeditor_0 .lia-button-Cancel-action","isGteForumV5":true,"messageViewWrapperSelector":".lia-threaded-detail-display-message-view","disabledReplyClass":"lia-inline-message-reply-disabled-reply"}); LITHIUM.Text.set({"ajax.reRenderInlineEditor.loader.feedback.title":"Loading..."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"useLoader":true,"blockUI":"","event":"LITHIUM:reRenderInlineEditor","parameters":{"clientId":"inlinemessagereplyeditor_0"}},"tokenId":"ajax","elementSelector":"#inlinemessagereplyeditor_0","action":"reRenderInlineEditor","feedbackSelector":"#inlinemessagereplyeditor_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.inlinemessagereplyeditor_0:rerenderinlineeditor?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434","ajaxErrorEventName":"LITHIUM:ajaxError","token":"6hJ46Y1ZNZXNJH7ZrzM4ha0ep9T0LBFvbpPFK1y1UGs."}); LITHIUM.InlineMessageEditor({"ajaxFeebackSelector":"#inlinemessagereplyeditor_0 .lia-inline-ajax-feedback","submitButtonSelector":"#inlinemessagereplyeditor_0 .lia-button-Submit-action"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadComponent","parameters":{"componentId":"messages.widget.emoticons-lazy-load-runner"}},"tokenId":"ajax","elementSelector":"#inlinemessagereplyeditor_0","action":"lazyLoadComponent","feedbackSelector":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.inlinemessagereplyeditor_0:lazyloadcomponent?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434","ajaxErrorEventName":"LITHIUM:ajaxError","token":"XfriACaPK9juof6LLXB1DTXLnbspO97K7ftdNVQunaI."}); LITHIUM.lazyLoadComponent({"selectors":{"elementSelector":"#inlinemessagereplyeditor_0"},"events":{"lazyLoadComponentEvent":"LITHIUM:lazyLoadComponent"},"misc":{"isLazyLoadEnabled":false}}); LITHIUM.Components.renderInPlace('recommendations.widget.recommended-content-taplet', {"componentParams":"{\n \"mode\" : \"slim\",\n \"componentId\" : \"recommendations.widget.recommended-content-taplet\"\n}","componentId":"recommendations.widget.recommended-content-taplet"}, {"errorMessage":"An Unexpected Error has occurred.","type":"POST","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.recommendedcontenttaplet:lazyrender?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=recommendations/contributions/page"}, 'lazyload'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "sortLabelsWidget", "actions" : [ { "context" : "envParam:viewOrderSpec", "action" : "rerender" } ] } ], "componentId" : "labels.widget.labels.sortable", "initiatorBinding" : false, "selector" : "#labelsTaplet", "parameters" : { "useSortHeader" : "false", "viewOrderSpec" : "nW1DvCH9sbTx8jBC8V4-yIFvgWhQLZWpe1UyOcM21TMz7p0s9zMfhAQdh28zOjzyh05QbR1UkvDQFZo6NVyEKUQ8OWbkqUwKisag0neZC2o7DfdcYcmxz6Y2CLEwuNppJWTOqmiO6LYg1ClezTdO_SrfVMN2tkqaFHZD7l1t74z48dc6LKj4MZS-q54gMSeO0z90NKCWWR6SzK1h8jEydAua4IjvTlz-qCb3_NenbZxjWz0GkIuQiSJX8uLsQuNVDck2-6lXUgpx0hDL_7FtFlP23ZmN2XrNSihId87KohpgYxD39f3lMxYDEsZCxpwzDf_T7gnExbd41tHpnuHYHpAcdTlBHZEoX4IkUQj4rnzHaEpFe4HIBbjE_On37igehfDfOBiV34nVozO6NP7JsMHlwC0ortdNcaVIyolmSAJe7VMQV90zPA2Ua7GweGHiv4HfpfyMv7tN_KelE9I-vyXpEBgdsRQDdoinudS3I1OdHVGPjsDmngpziqLZOii0bpWnVapbPcI43XTc0HjmA8p4kS6a69-wtHsWtHQf1vE." }, "initiatorDataMatcher" : "" }); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:sortLabelsWidget","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":"#labelsTaplet","action":"sortLabelsWidget","feedbackSelector":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.labelstaplet:sortlabelswidget?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434&t:cp=labels/contributions/page","ajaxErrorEventName":"LITHIUM:ajaxError","token":"nIDB-2nJF24FhG_LPUuCWFk3-P1CYepFYhMU0Bi7Ykc."}); ;(function($) { function makeid() { var text = ""; var possible = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789"; for (var i = 0; i < 5; i++) text += possible.charAt(Math.floor(Math.random() * possible.length)); return text; } $(document).ready(function () { $('body').on({ mouseenter: function(evt) { if ($(this).parents('.lia-component-users-widget-menu').length > 0) { return; } if ($(this).hasClass("disable-hovercard")) { return; } evt.preventDefault(); evt.stopPropagation(); $('.hc-user-profile').removeClass('hc-animate-in hc-is-shown'); if ($('.hc-user-profile', this).length > 0) { $('.hc-user-profile', this).addClass('hc-animate-in hc-is-shown'); return; } var unqId = makeid(); var userId = $(this).attr('href').substring($(this).attr('href').lastIndexOf("/")+1, $(this).attr('href').length); var divContainer = $(''); $(this).append(divContainer); $(divContainer).addClass('hc-animate-in hc-is-shown'); $.ajax({ url: '/plugins/custom/cisco/meraki/profile-card?tid=3691792826469949929', type: 'post', dataType: 'html', data: {"userId": userId, "unqId": unqId}, beforeSend: function() {}, success: function(data) { $('.info-container', divContainer).append(data); }, error: function() { console.log('your error message should go here.'); $('.info-container', divContainer).append(''); }, complete: function() { $('.spinner', divContainer).remove(); } }); }, mouseleave: function() { $('.hc-user-profile').removeClass('hc-animate-in hc-is-shown'); } }, 'a.lia-link-navigation.lia-page-link.lia-user-name-link,.UserAvatar.lia-link-navigation'); }) })(LITHIUM.jQuery); LITHIUM.PartialRenderProxy({"limuirsComponentRenderedEvent":"LITHIUM:limuirsComponentRendered","relayEvent":"LITHIUM:partialRenderProxyRelay","listenerEvent":"LITHIUM:partialRenderProxy"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:partialRenderProxyRelay","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":document,"action":"partialRenderProxyRelay","feedbackSelector":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.liabase.basebody.partialrenderproxy:partialrenderproxyrelay?t:ac=board-id/wireless-lan/message-id/24434/thread-id/24434","ajaxErrorEventName":"LITHIUM:ajaxError","token":"MQaXqDJlO4iMieiB2MrxciSls_dDPjBHlnqy5uYoJGI."}); LITHIUM.Auth.API_URL = '/t5/util/authcheckpage'; LITHIUM.Auth.LOGIN_URL_TMPL = '/plugins/common/feature/saml/doauth/post?referer=https%3A%2F%2FREPLACE_TEXT'; LITHIUM.Auth.KEEP_ALIVE_URL = '/t5/status/blankpage?keepalive'; LITHIUM.Auth.KEEP_ALIVE_TIME = 300000; LITHIUM.Auth.CHECK_SESSION_TOKEN = '4PFTqBjXNGDw9hcAND0PxHkq38X260CIcbwGz3iv1Wo.'; LITHIUM.AjaxSupport.useTickets = false; LITHIUM.Cache.CustomEvent.set([{"elementId":"link_2","stopTriggerEvent":false,"fireEvent":"LITHIUM:labelSelected","triggerEvent":"click","eventContext":{"uid":52,"selectedLabel":"other","title":"Other"}}]); LITHIUM.Loader.runJsAttached(); // -->
