TLS Support in Meraki AP to connect to LDAP when using Local Auth
alextsang010778
Hi all
I tried to configure the local auth in the Meraki AP with password authentication, so we configure the LDAP Servers in the local auth to verify the AD username and password. But the authentication test in the LDAP configuration failed, and it said no response from LDAP server.
Then I do packet capture to see what's wrong, and I found that the AP negotiate the LDAP server with SSL only, but those ciphers are disabled in the LDAP and only TLS1.2 is supported. So anyone know it is by design or how to change it to support TLS (I use LDAP browser to connect with the LDAPs and do packet capture, and the result is success and can see TLS1.2 negotiated.
At last, I found that the local auth with password authentication cannot support with WPA2 only. Is it by design too?
Best regards
Have you checked this article?
https://documentation.meraki.com/MR/Encryption_and_Authentication/Meraki_Local_Authentication_-_MR_8...
I follow this KB for the local auth authentication.
I suggest you to open a case with Meraki team support.
