Splash page language
BjornL
I'm trying to set up a simple Guest login page in Swedish using the built in splash pages. The problem is that the language option for the splash page is terrible, only about half of the text is actually translated. The resulting splash page is a mix of Swedish and English, and looks really inconsistent.
Some of this can be fixed by creating a custom theme, but not all. Is there any way to edit the text of form input fields or buttons on the splash page?
5 Replies 5
I dont know. But make sure to report it to meraki with a support case.
Once you copy the theme there is an option to edit the raw HTML and CSS pages.
https://documentation.meraki.com/MR/MR_Splash_Page/Custom_Splash_Page_Themes#Editing_the_Custom_Them...
I can edit parts om the pages, but some parts are contained in variables. For example, the form for the sponsor splash page is the variable "$MERAKI:MODERN_AUTH_SPONSOR_INFORMATION_FORM$" in the HTML. Is it possible to edit text in that form, like text on buttons or input fields in the form?
Delete the variable and replace it with whatever text you want.
But the variable contains the HTML form where you fill out name and email, not just text. Is it possible to recreate the form in the RAW HTML page?
