Splash page: accept box for SMS authentication
floatingpurr
Just browsing
Hi. I have a custom theme derived from Modern for SMS authentication. I'm wondering if there is a way to add a checkbox for accepting the policy before submitting the phone number.
The form is encapsulated in the following div:
<div id="signin_form" class="formarea form_links">
$MERAKI:MODERN_AUTH_SMS_INFORMATION_FORM$
</div>
but there is no way to modify its behavior through the editor since you can't upload any JS.
How can I do?
3 REPLIES 3
RaphaelL
Hi ,
On the splash page you can select ''User consent'' to show consent message to simply insert a check box :
Also the documentation states what html tags and attributes can be used : https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Customizing_the_Splas...
Thanks ,
Unfortunately, the user consent you mentioned is not displayed on the SMS auth page, even if it is properly set.
Hi @floatingpurr  did you find any solution to this ? My customer wants exactly the same setup i.e ability to consent before entering the phone number.
