Speedtest on Meraki very low
GiapCuong
Hi All
I'm having a problem with Meraki Mr33. I have 3 Meraki mr33 for 80 users. But recently, when one user has to download a file on the internet, our network interrupts immediately, I can't even ping to gateway. After that, I can see speed test on Meraki is very low (19Mbps/ download), while test by cable is 80 Mbps.
Link speed up to 1G and nice distance.
Please help
Thank you
Cuong
7 REPLIES 7
What band is the client on?
Any info in the wireless heath?
No duplex mismatch between switch/ap?
@GiapCuong has anything changed to cause this?
  • New firmware on MR33s or any other devices on the network (switches, firewalls etc.)
  • Client software update
  • Client driver update
What are the clients, Windows 10 laptops with Intel 8260 chipsets etc.?
What model(s) of switch, firewall etc. are you using?
GiapCuong
@cmr  latest version 27.5
I connected directly AP to FortiGate firewall and sure that driver always update
Client are windows 10, we have a lot laptop with different chipset
GiapCuong
I run dual ban, same duplex  and heath over 95%
To be clear - you are saying only a single user has this issue?
If so, it won't be the network, it will be the user.
Start up updating their WiFi drivers.  Power saving can often cause issues so try plugging the machine into AC power and see if the issue still happens.  Could be antivirus on the user's machine.
DJDonovan
Meraki Alumni (Retired)
Hey GiapCuong!
There have been some great comments by other community members so far, but I also just want to let you know that if you're using the Dashboard throughput tool it can give you potentially unreliable data.
More info on why can be found in this doc:
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Throughput_test_to...
To summarize. The dashboard throughput test can show lower speeds than you'd expect because it uses Meraki management traffic, which has the lowest priority compared to your production network traffic. Also, it's only testing throughput to the Meraki cloud, which may be different from your actual client throughput out to the internet.
What results do you get if you just run a normal throughput test using something public like speedof.me on a wireless client?
-Donovan
Thanks All,
I replace the current AP with another, It seems ok.
Thank for your suggestion all
Thank you
GiapCuong
