Sign into Wi-Fi network popup on Android tablet.
OATS-John
Just browsing
We have a couple Android tablets that I set up a Tablet Wi-Fi SSID with MAC Authentication via radius.  When these devices connect, we get a status bar alert that makes us click a few theses to sign in.  I do not have the problem on a few other devices that connect to this network.
I have attached pictures.
Here is the message we got.  You must select it to open it.
We then must click the 3 dots in the top left corner
The we must select Use this network as is for it to work,
Anyone have any thoughts?
4 REPLIES 4
Brash
What are the other devices that do work?
Different OS or version?
Have you disabled MAC randomization in the wifi advanced settings?
Devices that work:
  • iPads
    • iOS various versions
  • postal meter
    • Android unknown version
  • Smart TV
    • Various OSes
Yes, I did disable MAC randomization on the problem tablets.
Are you using the splash page on wifi of a mx?
I have the same issues on mx firmware 17.x/18.x
I am not using the splash screen.  I am running MR 29.4.1
