Same SSID but different network unable to connect laptop
Dimpleguy007
Hi Dude,
We have one SSID operated in two different sites.client authenticated by meraki cloud.
NETWORK(SITE 1)
All other AP's VLAN ID: 200
AP Model:MR 36 Firmware:28.5
NETWORK(SITE 2)
All other AP VLAN ID :3
AP Model:MR 36 Firmware:27.71
I  have added/allow user to access meraki Wi-Fi(Both network same SSID).
once i authorised user able to access wifi in site 1 later move to other site 2, the laptop unable to connect SSID automatically & keep trying to connect ,it was failed.i am trying to add the network manually  for workaround solution then user able to access wifi.
Kindly advise on this issue.
2 Replies 2
MarcP
Did you have a look here?
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring__WPA2-Enterprise_with_...
I do not use Meraki Auth, have got my own NPS, so I am not familiar with it, if it may only be for the network, not organization.
Or are your user switching between Orgs, not networks?
Hi marcp,
Our office operating two different location.
User switches between network not organisation with same ssid..
