SYSLOG messages on Meraki APs
Does anyone know if any syslog messages from a Meraki AP contain both the username and ip address in a single log?
We are looking to replace a Cisco wireless lan controller and APs with Meraki gear but it is important to be able to capture this kind of info in a syslog entry.
We managed to get this info from the wireless lan controller by using command
logging syslog facility client associate enable
This command extends the syslog capability on the WLC to send this info from SNMP information in the syslog entry
The syslog entry we get on from the WLC looks like the one below
12-02-2019 13:23:00 Local7.Error MYWLC11111: *Dot1x_NW_MsgTask_0: Dec 02 13:23:00.903: %APF-3-AUTHENTICATION_TRAP: apf_80211.c:19434 Client Authenticated: MACAddress:7c:95:f3:60:aa:f4 Base Radio MAC:7c:95:f3:60:aa:f4 Slot:2 User Name:jbloggs Ip Address:172.16.7.84 SSID:MYSSID
Any ideas out there??
Much appreciated
Accepted Solutions
Re: SYSLOG messages on Meraki APs
According to this it does, sort of:
https://jackofallit.wordpress.com/2016/03/02/meraki-ap-syslog-user-id-to-palo-alto-firewall/
Apparently the IP address is 0.0.0.0 on the first authentication, but filled in in consecutive tries.
Note: I haven't tried this. Also, kudos to Jack, whoever he is.
1 REPLY 1
