Re Simultaneous Login
CBMontesclaros
Hi All.
I am aware the there are only 2 options for simultaneous logins for the credentials of the Meraki splash page (Billing mode).
Can anyone suggest me if there is a work around to allow users to login there credentials to limited devices only (ex. 1 Laptop and 1 mobile device)
4 REPLIES 4
WirelesslyWired
This could be done with a radius server that monitors the number of user sessions. Cisco ISE is a good example. https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-22/204463-Configure-Max...
CCIEw# 45253 / CWNE# 249 / Senior Technical Marketing Engineer - Meraki MS Product
Thanks for the input aaburger85. However, having ISE is not yet considered in our current setup.
Aside from this resolution, do you think there are other ways to somehow "cheat" the current configuration re simultaneous login?
In a Guest WiFi environment without the user of any third party products - no.
Thanks for the input PhilipDAth.
