Question regarding to Prepaid card
Louein
Hello I am new to Cisco Meraki
I am currently using MR84 and doing some simulation before deploying the device.
I Made an SSID for Vouchers/Billings for clients who want to connect for a longer duration of connection.
I've set it to "Fast Prepaid login page" then I set splash page and a batch of prepaid card for that SSID.
But as I enter the PIN code(eg. 7CKG-8ZFM) from the batch that I made, it won't accept and it says that it was an "Invalid"
5 REPLIES 5
Re: Question regarding to Prepaid card
Louein
Ok, I followed the guide and enter a pin codes again
Then I got this Message
Wow you are having a bad day.  Wait 12 hours and if it is still happening open a case with support.
WANKiller
@Louein, With the above error message I'd open a support request and provide them with that information and screenshot of error message. They should be able to assist you from there (Looks like there may temporarily be a back-end problem.)
Louein
Apparently I'm having a Server Error when I put the Currency to "PHP".
Then I switch it out to "USD" then it work somehow...
