Port type between Access Point MR and Switch Access Cisco
Hello everybody,
Our office has over 100 clients and 4 APs MR33.
Our Topology:
(Meraki MX)  <----->  (Switch Access 2960 Cisco)  <----->  (AP MR33)
Meraki MX is the gateway + DHCP Server.
We have 4 VLANs:
- VLAN 10: Staff
- VLAN 20: Guest
- VLAN 30: Management
- VLAN 40: Partner
My question is when I configure port type between MR33 and C2960 is trunk. It worked, 4 SSIDs broadcasted and correctly VLANs assigned.
When I configure port type between MR33 and C2960 is access to Staff VLAN. It worked as well.
I have no idea why access ports still work. Please help me to understand it.
Thank you,
natuan
12 REPLIES 12
Re: Port type between Access Point MR and Switch Access Cisco
How is Client IP Assignment configured for the SSIDs under Wireless -> Access Control?
We use Bridge Mode for both situations.
Can you show us an image example of how you have this configured for one of the SSIDs? Curious to check something.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
For Staff WiFi, we use WPA2-Enterprise with radius and Bridge mode.
are you tagging the VLAN when you have bridge-mode enabled?
TwitterLinkedIn
I show config on another access switch 🙂
In fact, that AP is connecting to VLAN 10 - Staff with access port.
No VLAN tagging for Staff SSID and other SSIDs are Layer 3 roaming with a concentrator.
Just make a simple test, change between Bridge mode and Layer 3 roaming with a concentrator for guest VLAN
When I use Bridge mode, user has the same IP with staff VLAN.
When I use Layer 3 roaming with a concentrator and conventrate traffic on VLAN guest, user has the guest IP.
My conclusion is L3 roaming with a concentrator can bypass access port.
Kind of a big deal ww
Thats normal because al traffic tunnels to you wlc/appliance. The switch does not know whats inside the tunnel packets.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/SSID_Modes_for_Client_IP_Assignme...
can you add the full config of the cisco switch port when configured for access.
The configuration:
interface GigabitEthernet0/3
switchport access vlan 30
switchport mode access
spanning-tree portfast edge
end
you could check the vlans on the port.
#sh int G0/3 status
#sh vlan | i 0/3
it also works if you bounce the port?
oh I show config on another access switch. LOL
