Modify Self-Registration emails
Ima_NetAdmin
Just browsing
Hi
We are trialing some Meraki gear and testing the guest captive portal functions. We are using Splash page with Meraki Authentication sign-on and self-registration. We've been able to modify the splash page however, we cannot seem to find an option to change the email format/template/content sent to the self-registered users. Is it possible to edit the guest on-boarding emails?
Thanks!
2 Replies 2
I don't believe so.  You would have to change to using non-Meraki authentication, such as RADIUS (which is a lot more work).
Ryan-Zimmerle
This sounds like you may beed to look at the option of an external captive portal.  Perhaps these links are helpful.
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_captive_portal.pdf
https://documentation.meraki.com/MR/Splash_Page/Splash_Page_Overview
Ryan
